power level o rings
dick kennedy
181
I played with my valves several times then had most success when I went up
one size on the O rings. The extra material was just enough to seal.
Dick Kennedy
>Jerry Hoxsey power level 0 rings are # 7. Cork gaskets most times can't be
>reinstalled I use rubber ones I made from membrain roofing material like the
>old rubber inter tubes. If you cant find any call me I'll send you some.
also
>I use Napa k2 silicone compound it works well on these parts.[has many
>other uses its waterproof non-freezing non-melting] see you in Durango. Jim
>Anstett Loveland, Colorado
