My coach ('75 Palm Beach) has the original power level system. It works fine
except that the gate valve in the dash has a slow leak. It holds air well
enough that the leakdown is overnight.
The valves are a pin in hole sealed with an O ring. The leak is seepage
around the O ring. As near as I could tell the O rings are standard 9/32 OD
and I've replaced them with new. I believe the hole is a loose fit on a 9/32
drill. I've had the valve apart a half dozen times now and it's much
improved but still leaks.
Earlier I had read on this group that the valve bodies are porous so last
week I heated the cast bodies then dunked them in polyurethane varnish
hoping to seal any possible leaks in the castings. This didn't help
anything. On the last round I used polishing compound on the inside of the
holes. This improved things somewhat but I still have a slow leak on just
one of the pins.
The basic problem is that the O ring doesn't seal well in the hole. The fit
seems to be a little too loose and it probably doesn't help that it has to
slide in pot metal.
I'm sure someone has solved this one before so what are my options. Is
there an improved version of the valve available? Are there better O rings
that solve the problem? ATF has an additive that swells gaskets. Would it
help O rings? How about a stainless insert for the valve body?
Anyway I'd like to know what others have done to solve this.
Dick Kennedy
'75 PalmBeach
one of the pins.
slide in pot metal.
Dick Kennedy
'75 PalmBeach
