> The alternator output is an excellent source because if the engine should
> die before it has warmed up, the power will be removed from the choke. This
> will enable you to start again easier and idle better until the engine is
> warm.
That was my thinking.
> Another place you could use that would work as well is the R output of the
> alternator...or is it the I output? Sorry, CRS attack. In any event, it's
> the black wire, not the red battery sense wire, that is in the two-conductor
> plug on the alternator. This line goes high when the alternator is charging
> i.e. when the engine is running but goes low when the alternator isn't
> charging, as when the engine dies. Diesel GM pickups used this wire for the
> glow plug timer heaters, the diesel equivalent to an electric choke...
Actually, I was thinking of tapping onto the center isolater terminal.
Should only be hot when the alternator is charging.
Patrick
Patrick Flowers
Mailto
atrick
The GMC Motorhome Page
http://www.gmcmotorhome.com
