Power consumption of fridge at 12 Volts
My marine Vitrifrigo (Danfoss Compressor) is full size with a huge freezer and draws just over 5 amps on 12 volts
Their spec sheet says
12 Vdc /65 W (5.38 A)
On mains it claims 65 watts as well. Imagine that!
Dolph
DE AD0LF
Wheeling, West Virginia
1977 26’ ex-PalmBeach
“The Aluminum and Fiberglass Mistress”
"--OO--[]---O-"
> Based on what I see on my Trimetric battery meter, I would guess my Norcold 641.3 draws somewhere around 15 amps on the 12v setting. I generally see
> about a 6 - 8 amp draw on the meter while my solar is is charging at 8 - 10 amps. I generally just shut the fridge off if I am going to be parked
> for a short time for lunch etc. and turn it back on once we are about to get underway. I always drive with the propane valve in the off position at
> the recommendation of Mac the Fire Guy.
> Carl Stouffer
> '75 ex Palm Beach
> Tucson, AZ.
> Chuck Aulgur Reaction Arm Disc Brakes, Quadrabags, 3.70 LSD final drive, Lenzi knuckles/hubs, Dodge Truck 16" X 8" front wheels, Rear American Eagles,
> Solar battery charging. GMCSJ and GMCMI member
I have a NORCOLD 3 WAY refrigerator in the GMC. I have had it for a very long time, originally bought new for a different RV.
I like it a lot but your question is a good one.
Not sure why you are asking about the loading of the 12v dc system, it is a lot, about 10 amps. It is enough that when you travel down the road you
can be on the 12v dc power but when you stop and shut the engine down, you need to turn off the 12v dc. Using the DC power to run the 3 way will run
the battery down quickly.
The propane is great when camping and the 120 v ac is also great if you can plug in at campsites.
I pretty much use the 12v dc when driving down the road with the engine running, but when you stop don't forget to turn off the 12v dc.
GatsbysCruise. \
74GMC260 Former Glacier Model style. \
Waukegan, Illinois \ Keep those MiniDiscs Spinning \ MY GREYHOUND IS FASTER THAN YOUR HONOR ROLL STUDENT \ WindowsXP-Win7-Win8.1-UBUNTU STUDIO -
UBUNTU VOYAGER - Berzin Auto Center
