I am no expert on this but I am reading the literature and trying to get it
all straight
This reference
http://offroad-net.com/~ifsja/tech/motors/egrvacuum.html
says:
Port vacuum signal is generated via Burneulli's Principle in the carb's
venturi. The larger the volume of air flowing
through the carb., the stronger the vac. signal. At idle there is very
little air flowing through the carb and the vac. signal is very small.
Basically no vacuum. At wide-open throttle (WOT) and high RPM, the port
vacuum signal is strongest.
This reference
http://www.emsgas.com/vacuum1.htm
says:
PORTED VACUUM
Is obtained from a passage just above the closed throttle. At idle, no
vacuum is applied this port due to its location. As the throttle is
opened, this port is exposed to manifold vacuum, so vacuum at this port
begins to increase. Since ported vacuum is actually manifold vacuum applied
to a different passage it will also be near zero when wide open throttle.
As Emery points out the GMC manual says the original equipment distributor
is connected to PORTED VACUUM when the engine is cold and MANIFOLD VACUUM
when the engine is hot using the TVS valve.
When I installed my Holley 3210 TBI I tested the ports and found the two
outside ports facing the front of the engine were Manifold Vacuum. The
center port under the PCV port was ported vacuum and there was no vacuum
there until the butterfly were opened and then it went up to 20 lb. This
is just what Howell said was the configuration.
The Howell instructions say to remove the TVS valve and put the distributor
on the port nearest the passenger seat. This would be manifold Vacuum.
However when I talked to Tom at Howell last week, he said the distributor
should be connected to the ported Vacuum which would be the center port.
So I guess I will have to call Howell next week and see if they can resolve
this. My GMC bucked and backfired with the distributor was connected to
manifold vacuum.
gene
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
all straight
This reference
says:
This reference
says:
PORTED VACUUM
manifold vacuum.
gene
mr.erf
