Pork chop
If you were able to raise the front, even a small amount, you will be ahead
of the game when you get the longer bolts. All the slop is now taken up,
and the longer bolts will show results right away. Hang in, it is a steep
learning curve, but not one you are likely to forget anytime soon.
Salem, Oregon
On Tue, Nov 19, 2019, 2:31 PM Bruce Hart via Gmclist <
> Forgot to add that I did not index the pork chop. Wanted to get complete
> data before changing anything.
> > Removed pork chops cleaned up torsion bar and chops. Reinstalled and
> > adjusted screws to max. Set the ride height on the rear.
> > Front ride height was out 1/2" low on both sides. Took a test drive on
> > I-25 for twenty minutes. Checked ride height on rear and it was correct.
> > Ride height on front is low by 1" on both sides. Waiting for the longer
> > torsion bolts to see if I can get the ride height to correct dim.
> > On Tue, Nov 19, 2019 at 12:04 PM Larry via Gmclist <
> >> > BAD idea!
> >> > The torsion bars are pre-stressed during manufacture. There's a limit
> >> to
> >> > the amount of stress a body can withstand without "yielding", or
> taking
> >> a
> >> > permanent set. After the yield point, the strength of the body is
> >> GREATLY
> >> > reduced. To allow a greater range of movement (stress) possible
> without
> >> > reaching the yield (and loss of strength) point, the bar is "pre-bent"
> >> in
> >> > the opposite direction of the expected load. That's why the bars have
> >> the
> >> > L and R marking -- to be sure they'll ONLY be located correctly.
> >> Reversing
> >> > the location would greatly increase the probability of the bar taking
> >> > additional set -- or worse.
> >> > Ken H.
> >> > On Mon, Nov 18, 2019 at 10:08 PM Larry via Gmclist
> >> > > What would happen if you swapped bars from left to right side of
> >> coach?
> >> > > Twisting in the other direction....Good or bad idea?
> >> > > Larry
> >> > > 78 Royale w/500 Caddy
> >> > > Menomonie, WI.
> >> Thanks Ken,
> >> I don't have the problem, but if I did I always wondered if I could do
> >> that....now I know. :)
> >> Larry
> >> Menomonie, WI.
> >> _______________________________________________
> >> GMCnet mailing list
> >> Unsubscribe or Change List Options:
> >> http://list.gmcnet.org/mailman/listinfo/gmclist_list.gmcnet.org
> > Bruce Hart
> > 1976 Palm Beach
> > Milliken, Co
> > GMC=Got More Class
> Bruce Hart
> 1976 Palm Beach
> Milliken, Co
> GMC=Got More Class
That was the next item Jim K. suggested when I called and talked to him.
I need 1 1/8 " on the left side and 1" on the right side to be in spec.
On Wed, Nov 20, 2019 at 10:27 AM Russell Keith via Gmclist <
> Bruce,
> Would the adjustable pork chop help with your situation?
> http://www.appliedgmc.com/prod.itml/icOid/1118
> Russell
> Russell Keith,
> 1978 E2 "Harry" 403 (still carbureted), Danny Dunn Tranny, Thorley, Stock
> Brakes w/Remote Vacuum Brake Booster, Quad Bags, Dakota Digital Dash, 6.5 kW
> Onan, Dunedin, Florida
Bruce Hart
1976 Palm Beach
Milliken, Co
GMC=Got More Class
Bruce,
You didn’t indicate in your follow-up whether you had verified the torsion bar sockets in the LCAs for expansion/cracks/blowout.
I’d hate to see you throw $$ at the wrong parts.
Confirming the LCA condition helps with further diagnosis as well as helping the next guy who digs for answers when they have a similar issue in the future.
Les Burt
Montreal
'75 Eleganza 26'
>> Bruce,
>> Russell
>> Russell Keith,
>> GMCnet mailing list
> Bruce Hart
> 1976 Palm Beach
> Milliken, Co
> GMC=Got More Class
Sir, 6 turns = ~1" raise.
> > Bruce,
> > Russell
> > Russell Keith,
> Bruce Hart
> 1976 Palm Beach
> Milliken, Co
> GMC=Got More Class
C. Boyd
76 Crestmont
East Tennessee
Not an exact result. The threads on the adjustment bolt add up to that, but
the old bugaboo "stiction" rears its ugly head. But, it's a good place to
start.
Salem, Oregon
On Wed, Nov 20, 2019, 7:20 PM Charles Boyd via Gmclist <
> > > Bruce,
> > > Russell
> > > Russell Keith,
> Stock
> 6.5 kW
> > > GMCnet mailing list
> > Bruce Hart
> > 1976 Palm Beach
> > Milliken, Co
> > GMC=Got More Class
> C. Boyd
> 76 Crestmont
> East Tennessee
All, I am currently rebuilding my front end, not because it was giving any
trouble, just because it still had all original bushing, ball joints, etc.
Anyway, I have the hubs seperated, the top A arm off, and the bottom A arm
free from the frame however the torsion bar does not seem to want to let go
of the A arm. (of couse I did unload the torsion bar at the pork chops
first) So now the pork chops are loose, and the bottom A arms are loose,
however neither the pork chop nor the A arm wants to let go of the torsion
bar. Any thoughts? Tomorrow morning I am planning on putting my slide
hammer thorough the front A arm to frame bolt hole and see if I can slide
hammer the A arm off of the bar... of course both sides are in the exact
same state of disassembly with both lower A arms needing to let go of the
torsion bars. Some additional information, if I wiggle the A arm up and
down you can feel the torsion bar move just a little inside A arm.
Thanks,
Rich
On Wed, Nov 20, 2019 at 10:27 PM James Hupy via Gmclist <
> start.
> Jim Hupy
> Salem, Oregon
> him.
> > > > Bruce,
> > > > Russell
> > > > Russell Keith,
> > Stock
> Dash,
> > 6.5 kW
> > > > GMCnet mailing list
> > > Bruce Hart
> > > 1976 Palm Beach
> > > Milliken, Co
> > > GMC=Got More Class
> > > GMCnet mailing list
> > C. Boyd
> > 76 Crestmont
> > East Tennessee
Finally got the extended threaded torsion bolt. Miscommunication, post
office error, but got the bolt on Saturday the 23.
For what ever reason I went ahead and maxed out the threads, went for a
cruise over several dips and remeasured the ride height
Front left 13 1/8
Front right 13 3/16
Rear left 11 11/16
Rear right 11 5/8
Rear ride height was obtained by air suspension system.
Will need to test run some more before coach goes back to owner in Colorado
Springs, Co.
On Wed, Nov 20, 2019 at 8:27 PM James Hupy via Gmclist <
> start.
> Jim Hupy
> Salem, Oregon
> him.
> > > > Bruce,
> > > > Russell
> > > > Russell Keith,
> > Stock
> Dash,
> > 6.5 kW
> > > > GMCnet mailing list
> > > Bruce Hart
> > > 1976 Palm Beach
> > > Milliken, Co
> > > GMC=Got More Class
> > > GMCnet mailing list
> > C. Boyd
> > 76 Crestmont
> > East Tennessee
Bruce Hart
1976 Palm Beach
Milliken, Co
GMC=Got More Class
Rich, my first try on getting torsion bars off the arm was the same
experience that you are having. Somehow I was able to get a little
movement and than I would work the bar back and forth and every time would
get a little more movement until it finally came all the way out.
> Front left 13 1/8
> Front right 13 3/16
> Rear left 11 11/16
> Rear right 11 5/8
> Colorado Springs, Co.
>> but
>> start.
>> Jim Hupy
>> Salem, Oregon
>> him.
>> spec.
>> > > > Bruce,
>> > > > Russell
>> > > > Russell Keith,
>> > Stock
>> Dash,
>> > 6.5 kW
>> > > > GMCnet mailing list
>> > > Bruce Hart
>> > > 1976 Palm Beach
>> > > Milliken, Co
>> > > GMC=Got More Class
>> > > GMCnet mailing list
>> > C. Boyd
>> > 76 Crestmont
>> > East Tennessee
>> > GMCnet mailing list
>> GMCnet mailing list
> Bruce Hart
> 1976 Palm Beach
> Milliken, Co
> GMC=Got More Class
Bruce Hart
1976 Palm Beach
Milliken, Co
GMC=Got More Class
Vibrate impact them apart.
Sully
Bellevue wa
On Tue, Nov 26, 2019 at 5:19 PM Bruce Hart via Gmclist <
> > Front left 13 1/8
> > Front right 13 3/16
> > Rear left 11 11/16
> > Rear right 11 5/8
> >> but
> to
> >> start.
> >> Jim Hupy
> >> Salem, Oregon
> >> him.
> >> spec.
> >> > > > Bruce,
> >> > > > Russell
> >> > > > Russell Keith,
> Thorley,
> >> > Stock
> >> Dash,
> >> > 6.5 kW
> >> > > > GMCnet mailing list
> >> > > Bruce Hart
> >> > > 1976 Palm Beach
> >> > > Milliken, Co
> >> > > GMC=Got More Class
> >> > > GMCnet mailing list
> >> > C. Boyd
> >> > 76 Crestmont
> >> > East Tennessee
> >> > GMCnet mailing list
> >> GMCnet mailing list
> > Bruce Hart
> > 1976 Palm Beach
> > Milliken, Co
> > GMC=Got More Class
> Bruce Hart
> 1976 Palm Beach
> Milliken, Co
> GMC=Got More Class
The torsion bars have likely been there for 40 years. The old soap based
grease, is now thoroughly mixed with road grime, and very hard and thick.
Use something to dissolve the crud in there. Your choice of solvents. I use
red can brake kleen. But other stuff will work as well. Spray the hell out
of it, and let it sit, then wiggle the heck out of it. Get serious with
wrestling with it. It will come apart. JWID.
Salem, Oregon
On Tue, Nov 26, 2019, 5:51 PM Todd Sullivan via Gmclist <
> Sully
> Bellevue wa
> would
> > > Front left 13 1/8
> > > Front right 13 3/16
> > > Rear left 11 11/16
> > > Rear right 11 5/8
> that,
> > >> but
> > to
> > >> start.
> > >> Jim Hupy
> > >> Salem, Oregon
> to
> > >> him.
> > >> spec.
> > >> > > > Bruce,
> > >> > > > Russell
> > >> > > > Russell Keith,
> > Thorley,
> > >> > Stock
> > >> Dash,
> > >> > 6.5 kW
> > >> > > > GMCnet mailing list
> > >> > > Bruce Hart
> > >> > > 1976 Palm Beach
> > >> > > Milliken, Co
> > >> > > GMC=Got More Class
> > >> > > GMCnet mailing list
> > >> > C. Boyd
> > >> > 76 Crestmont
> > >> > East Tennessee
> > >> > GMCnet mailing list
> > >> GMCnet mailing list
> > > Bruce Hart
> > > 1976 Palm Beach
> > > Milliken, Co
> > > GMC=Got More Class
> > Bruce Hart
> > 1976 Palm Beach
> > Milliken, Co
> > GMC=Got More Class
In the one corner, is the crusted old torsion bar, looking determined not
to be beaten. In the other corner is his challenger, tenacious with a "not
going to beat me" attitude, that and a nice cup of hot coffee! I shall
squirt the heck out of them and then ring the fight bell. I'll let you know
how it ends up.....
Rich
On Wed, Nov 27, 2019 at 1:35 AM James Hupy via Gmclist <
> Jim Hupy
> Salem, Oregon
> > Sully
> > Bellevue wa
> > would
> post
> for a
> > > > Front left 13 1/8
> > > > Front right 13 3/16
> > > > Rear left 11 11/16
> > > > Rear right 11 5/8
> > that,
> > > >> but
> place
> > > to
> > > >> start.
> > > >> Jim Hupy
> > > >> Salem, Oregon
> > to
> > > >> him.
> in
> > > >> spec.
> > > >> > > > Bruce,
> > > >> > > > Russell
> > > >> > > > Russell Keith,
> > > Thorley,
> > > >> > Stock
> Digital
> > > >> Dash,
> > > >> > 6.5 kW
> > > >> > > > GMCnet mailing list
> > > >> > > Bruce Hart
> > > >> > > 1976 Palm Beach
> > > >> > > Milliken, Co
> > > >> > > GMC=Got More Class
> > > >> > > GMCnet mailing list
> > > >> > C. Boyd
> > > >> > 76 Crestmont
> > > >> > East Tennessee
> > > >> > GMCnet mailing list
> > > >> GMCnet mailing list
> > > > Bruce Hart
> > > > 1976 Palm Beach
> > > > Milliken, Co
> > > > GMC=Got More Class
> > > Bruce Hart
> > > 1976 Palm Beach
> > > Milliken, Co
> > > GMC=Got More Class
> > > GMCnet mailing list
Gratituitous use of a Manny T. "Precision Adjustment Device", better known
as a big hammer, is sometimes required. (Grin)
Salem, Oregon
On Wed, Nov 27, 2019, 3:23 AM Rich Kinas via Gmclist <
> how it ends up.....
> Rich
> use
> out
> > Jim Hupy
> > Salem, Oregon
> > > Sully
> > > Bellevue wa
> > > would
> > > > On Tue, Nov 26, 2019 at 6:14 PM Bruce Hart
> > post
> > for a
> > > > > Front left 13 1/8
> > > > > Front right 13 3/16
> > > > > Rear left 11 11/16
> > > > > Rear right 11 5/8
> > > that,
> > > > >> but
> > place
> > > > to
> > > > >> start.
> > > > >> Jim Hupy
> > > > >> Salem, Oregon
> talked
> > > to
> > > > >> him.
> > in
> > > > >> spec.
> > > > >> > > > Bruce,
> > > > >> > > > Russell
> > > > >> > > > Russell Keith,
> > > > Thorley,
> > > > >> > Stock
> > Digital
> > > > >> Dash,
> > > > >> > 6.5 kW
> > > > >> > > > GMCnet mailing list
> > > > >> > > Bruce Hart
> > > > >> > > 1976 Palm Beach
> > > > >> > > Milliken, Co
> > > > >> > > GMC=Got More Class
> > > > >> > > GMCnet mailing list
> > > > >> > C. Boyd
> > > > >> > 76 Crestmont
> > > > >> > East Tennessee
> > > > >> > GMCnet mailing list
> > > > >> GMCnet mailing list
> > > > > Bruce Hart
> > > > > 1976 Palm Beach
> > > > > Milliken, Co
> > > > > GMC=Got More Class
> > > > Bruce Hart
> > > > 1976 Palm Beach
> > > > Milliken, Co
> > > > GMC=Got More Class
> > > > GMCnet mailing list
> > > GMCnet mailing list
