METHOD
STANDING START - pedal to the floor - record times for
zero - to 30 / 40 / 50 / 60 / 70 miles per hour
CONDITIONS
Coach Type ---- '73XPD - 26'
Engine ---- 455
Year ---- '73
heads ---- "j"
oil ---- Mobil 1 15W/50
ignition ---- "HEI" (Springfield)
initial---- 10 degrees
advance---- ported vacuum
comp. ---- 170 psi (approx - all cylinders)
vacuum ----
idle ---- 20" (neutral 850 rpms approx)
50mph ---- 16"
60mph ---- 14"
70mph ---- 12"
drive ratio---- 3.07 (OEM) Mobil 1
shift kit ---- no (OEM)
tires ---- XPS RIB
---- 8.75 X 16.5
---- 65 lbs (all)
load gas ---- full
L/P ---- 90% full
waste ---- empty
water ---- full
cargo ---- 150lbs tools/supplies ?
Gas ---- 87 octane (true gasoline)
A/C ---- 1/center - off
road ---- level
air temp ---- 70 degrees (love Florida weather)
RESULTS
0-30 ---- 7 seconds
0-40 ---- 11 seconds
0-50 ---- 18 seconds
0-60 ---- 27 seconds
0-70 ---- 40 seconds
Pete Papas-->http://members.tripod.com/~mehawk_ii/index.html
. ___________ (MY TOYS) (904)672-0571
./_][__][] []| 1973 GMC M/H 1976 Bi-Centennial Harley M/C
.*O-------OO-* Painted Desert 1979 280ZX Datsun (1 of 1000)
Do You Yahoo!?
Talk to your friends online with Yahoo! Messenger.
http://im.yahoo.com
CONDITIONS
Engine ---- 455
Year ---- '73
heads ---- "j"
vacuum ----
50mph ---- 16"
60mph ---- 14"
70mph ---- 12"
tires ---- XPS RIB
---- 8.75 X 16.5
---- 65 lbs (all)
load gas ---- full
L/P ---- 90% full
waste ---- empty
water ---- full
road ---- level
RESULTS
0-30 ---- 7 seconds
Do You Yahoo!?
http://im.yahoo.com
