Heinz are you using 1-888-666-3355? Mondello also has a web page that you
can order on.
>Thanks Thomas,
>I called Mondello the other day but gave up holding
>I was going to order the book and catalog as a starter but it sounds like
>you have the research already done. Thank You
I'll try to get my order
>in on Monday so that the stuff be home by the time I am.
>Heinz
>Something I forgot to add Heinz. I would and am going to also install
>Mondellos camshaft thrust button and bolt to eliminate camshaft walk and
>wear of the timing chain and reduces timing problems. It is part # TB745
>and is $18. Be sure if you order it you tell them that the cam is still in
>the engine.
>>Heinz --
>>I changed to a Cloyes on our GMC, I got it from Chuck Stoddard because I
>>couldn't find the same model anywhere else.
>>It was the 'middle' chain, a true roller chain. They make a 'standard',
>this
>>one, which I'd recommend called 'heavy duty' and an 'extra heavy duty'. I
>>don't have the part number, but I'm sure someone will post it if someone
>>else doesn't.
>>Personally, I think the cost of changing a chain is cheap insurance, and
>>have changed them on many high mile vehicles. It isn't expensive, actually
>>cheaper in the long run since you get better valve timing, engine
>>performance and economy.
>>I don't know if the 455 is an interference engine that is, improper valve
>>timing could let the valves kiss the piston tops. I do know that you won't
>>get far if the chain gets loose enough that it jumps a tooth. Been there,
>>done that with a 301 cube Pontiac. Not recommended.
>>That's my 2=A2 worth.
>>Mark
>>> -----Original Message-----
>>> From: owner-gmcmotorhome
>>> [mailto
wner-gmcmotorhome]On Behalf Of
>>> heinz
>>> Sent: Saturday, May 01, 1999 2:16 PM
>>> To: gmcmotorhome
>>> Subject: GMC: Pondering Timing Chain replacement
>>> As I now have about 100k+ on the 2nd engine and the first one
>>> w.ent at 135-ish with timing chain failure being a contributing
>>> factor (so I was told
I'm contemplating changing the timing
>>> chain, water pump and whatever else is up there when I get home
>>> from this trip.
>>> I've been trying to collect info and wisdom from some of my
>>> customers (who are in automotive) to get opinions as to whether
>>> to or not to. Feedback was mixed to say the least and ranged from
>>> shoulda already to if it ain't broke...
>>> However, based on the past experience I'm planning to go ahead
>>> anyways. Now the quander and question... where to get the timing
>>> chain and what is the variety that will give me most service and
>>> peace of mind?
>>> Cinnebar? Mondello? Jim Bounds... you jump right on in here please
>>> I actually think I have one that originated at Clasco years back,
>>> but I'd rather get new and have a better chance that I only have
>>> to do it once.
>>> At the same time I'm going to try and find a waterpump that was
>>> built for reverse rotation, i.e. serpentine setup, though I've
>>> not had cooling problems until yesterday when the fanclutch said=
bye-bye.
>>> Are there any high milagers out there that have changed timing
>>> chain and are there some that wish they had?
>>> Any and all thoughts welcomed.
>>> TIA - Heinz
>>> P.S. Any other related stuff that I should be considering while
>>> up there digging around the front?
>Tom & Marg Warner
>Vernon Center NY
>1976 palmbeach
>"The beautiful Mohawk Vally"
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
