Last week while plugged in at home my GFI outlet popped at some point. I had been using my vacuum cleaner (not the GMC one). I plugged it in again
and later I noticed the GFI outlet was buzzing, not super loud but pretty loud.
So, I plugged into my house outlet (non GFI). This GFI outlet is new, the whole line to the garage is new we didn't have one before.
I plugged in this morning, waited for it to start buzzing- maybe 5 minutes. Then I shut breakers off. It would change the pitch of the buzz. I got
to the one labeled water heater (on my panel it's the upper right) and the buzzing stopped. So, now what do I do? The water heater was off, I have a
wire coming from the breaker box to an normal switch that says water heater. It's always off, I use propane to heat my water.
It's like it's not grounding out, but it's sort of grounded? It sounded like this, but only when I was plugged in.
https://www.youtube.com/watch?v=Fw2MdV1X1iU
thanks
kelly
1978 Kingsley
Putney VT
thanks
kelly
1978 Kingsley
Putney VT
