Plea for help...
robin hood
1,061
https://youtu.be/VGeJN6RLC40
Ok, after quitting working for the Feds and moving from MS to Florida, I
have FINALLY stabilized enough that I can justify working on my coaches
again.
I have somehow lost the keys to BOTH coaches (as well as the gate to the
storage yard!) in the move. Rumor has it that door and ignition keys can be
cut by a good locksmith without needing to replace them.
The aluminum wheels need swapped around from the Royale to the Palm Beach.
The Palm Beach needs the fuel tanks reinstalled.
I can try to take some time off work, but some extra hands who know what
they're doing would be a big help. :) Goal is to get these to Florida. I
met a guy at Dothan who indicated interest in the Royale and may be willing
to assist, but I've lost his contact info. :)
Robin
Robin Hood
Jacksonville FL
2013 Subaru Outback "Top Flight"
1968 Pontiac Catalina "The Cheshire Cat"
1978 GMC Royale motorhome "Pinto Bean"
1977 GMC Palm Beach motorhome "Barn Queen"
Re-keying that vintage lock is not difficult. On the door lock remove one of them and take it to almost any locksmith.
OR.. Get a new pair from Autozone Part # DL15250 (that is 2 keys and 2 locks in the set) It is around $16.00.
On the ignition switch, which is a different key than the door, remove the tumbler assembly from the steering column and get a new one with keys from
Autozone. (Part# LC14260 or LC14290) Most of them are worn anyway. The price is $18.99 or $15.39.
AZ will loan you a steering wheel puller for free. The last one that I installed, I replaced the ignition one in the AZ parking lot with their
puller.
You also need the steering lock depressor tool and some small flat blades to remove the lock ring and depress the cylinder pin. As well as philips
and the wheel nut socket long extension and ratchet.
John Lebetski
Woodstock, IL
Is that unique to our coaches or would a locksmith be familiar with this
procedure?
On Thu, Feb 9, 2017 at 8:00 AM John R. Lebetski
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
Robin Hood
Jacksonville FL
Standard throughout GM vehicles of the era. All the same. Ignition locks
made by Briggs and Stratton division of General Motors.
procedure?
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
Robin Hood
Jacksonville FL
I posted on facebook the tools that he is describing.
steering wheel puller(you can rent one, harbor freight, ect). I have a very cheapo one and has always worked.
https://www.amazon.com/Performance-Tool-W150-Steering-Removal/dp/B0002KO0QS/ref=sr_1_7?ie=UTF8&qid=1486657341&sr=8-7&keywords=steering+wheel+puller
there is a spring plate that needs to be pushed down, and there is a tool for that:
https://www.amazon.com/Powerbuilt-648466-Steering-Wheel-Removal/dp/B004KED7RU/ref=sr_1_6?ie=UTF8&qid=1486657341&sr=8-6&keywords=steering+wheel+puller
again a very common tool. You can get by without it by prying and pushing, but that compressor makes it simple.
I am not sure I agree with that all locks are the same. I tried swapping my ignition cylinder out with a chevy suburban and i think maybe a GMC
Jimmy lock a couple times. They sure look the same, but there was some difference, I can't remember what. I ended up having a locksmith do a key
up, and kicked myself for how easy that was and the time I wasted taking the suburban cylinders out of the vehicles.
again as the facebook post showed, search that coach over, there always seems to be a key hidden somewhere in the past 40 years.
Jon Roche
75 palm beach
St. Cloud, MN
I may be wrong about this, but I'm pretty sure the glove box lock is the same as the entry door lock and the electric hook-up lock, and is easy to
remove. Some of those even have a lock code on them. That would help only if you can get into the coach.
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
Solar battery charging
If it was me, I'd run it home on a boat tank so I could take mt time reinstalling the gas tanks. And if that's the set of tires I gave you, I don't
think I'd try for Jacksonville on them.
--johnny
Braselton, Ga.
"The road goes on forever, and the party never ends" --Robert Earl Keen
Robin, what's your current email?
--johnny
Braselton, Ga.
> procedure?
> > John Lebetski
> > Woodstock, IL
> > 77 Eleganza II
> /gmclist_list.gmcnet.org[/color][/url]
> Robin Hood
> Jacksonville FL
A locksmith can make a key for the lock after it is removed and delivered to him. Any GM mechanic familiar with vehicles of this era can remove the
lock.
Like I said before I removed and replaced mine in the parking lot at AutoZone.
It takes about 5 minutes with the proper tools to remove the steering column lock. You will need the two tools borrowed from AZ in the same kit. You
will also need a set of 3/8" deep well sockets and a couple of screw drivers.
I still recommend that you just replace the cylinder(s) rather than re-key them. I just checked and new door cylinders are in stock at my local
AutoZone. They are very common GM parts.
I am several hundred miles from my coaches, if I still lived in the same
city is the number we will be having a much different conversation. I'm
having to do most of this either remote control by hiring specialists or
host some sort of work rally. :-)
> Robin:
> If you want to get in the GMC's without a Locksmith, Watch this Jim
> Bounds video.
> https://www.youtube.com/watch?v=go-jJVim_5Y
> Mike K.
> '75 PB
> Southeast Michigan
Robin Hood
Jacksonville FL
Hey Ken my email address is loxley
As I think about it further, I think I like the idea of a 20 gallon fuel
cell sitting in my hallway instead of trying to hang in redo the fuel
system so far away from home.
Robin Hood
Jacksonville FL
Heya Tom!
Will do! Hafta be tomorrow after my hearings though.
I've been road warrioring it. Jacksonville to Jackson to St Pete, back to
Jacksonville tomorrow after hearings... I have truck butt.
> Robin, Call me. Tom, ms ii
> 1975 GMC Avion
> KA4CSG
Robin Hood
Jacksonville FL
My son had his car stolen, when it ran out of gas it was abandoned and
towed to the police lock up lot. He was notified through the registration
to come get it. Of course he had only one set of keys and they were in the
car when stolen but not in the ignition when towed. We were give the
number of a locksmith through the impound yard and was told we had 10
minutes to get the vehicle out. Locksmith showed up in a Safari van with
his tools in the back and was able to make a key in two tries at a cost of
$50.
Good Luck!
> Heya Tom!
> > 1975 GMC Avion
> > KA4CSG
> Robin Hood
> Jacksonville FL
Bruce Hart
1976 Palm Beach
Milliken, Co
GMC=Got More Class
> As I think about it further, I think I like the idea of a 20 gallon fuel cell sitting in my hallway instead of trying to hang in redo the fuel
> Robin Hood
> Jacksonville FL
And don't worry about playing musical wheels between the two sets you want to swap out. Get into them the least damaging way you can think of, inflate
the tires and bags, hotwire them, and head for home.
Do everything else on the home court where Murphy has less advantage over you.
73 23' Sequoia 4 Sale
Upper Alabama
"When I grow up I am going to be a curmudgeon."
That's fair warning for EVERYBODY to get multiple spare key sets made for EVERY vehicle!
I have four sets for my GMC motorhome.
~~ ~ D C "Mac" Macdonald ~ ~~
~ ~ Amateur Radio - K2GKK ~ ~
~ ~ Since 30 November '53 ~ ~
~ ~ USAF and FAA, Retired ~ ~
~ Member GMCMI and Classics ~
~ ~ ~ Oklahoma City, OK ~ ~ ~
~~ ~ ~ "The Money Pit" ~ ~ ~~
~ ~ ~ ~ TZE166V101966 ~ ~ ~ ~
~ ~ ~ '76 ex-Palm Beach ~ ~ ~
~~ k2gkk + hotmail dot com ~~
~ www.gmcmhphotos.com/okclb ~
______________
"--OO--[]---O-"
Sent: Thursday, February 9, 2017 20:46
Subject: Re: [GMCnet] Plea for help...
$50.
Good Luck!
> Heya Tom!
> > 1975 GMC Avion
> > KA4CSG
Gmclist Info Page - list.gmcnet.orghttp://list.gmcnet.org/mailman/listinfo/gmclist_list.gmcnet.org
list.gmcnet.org
To see the collection of prior postings to the list, visit the Gmclist Archives. Using Gmclist: To post a message to all the list members, send email ...
> Robin Hood
> Jacksonville FL
list.gmcnet.org
Bruce Hart
1976 Palm Beach
Milliken, Co
GMC=Got More Class
list.gmcnet.org
I can get my door unlocked using a long squiggle pick or one of the long upholstery (trim) pin (plastic push-in fasteners)removal tools from Harbor
Freight by going in through the fridge access door and slipping the tool between the cabinet and the vehicle body and lifting the lock knob.
Terry Kelpien
ASE Master Technician
73 Glacier 260
Smithfield, Va.
