Piston Rod Master Cylinder----Booster
herm beeck
131
Paul
To what type of Master Cylinder are you changing to?
Herm
> Netters.
> I need to increase the length of the piston rod between the Master
> Cylinder and Power Booster by 1/8". The installation of a different
> master cylinder an the positioning of the support bracket will
> necessitate this change. Any suggestions will be appreciated.
> Frank SW Indiana
> Home of Toyota
> TUNDRA
> ______________________________________________________
> Get Your Private, Free Email at http://www.hotmail.com
DO YOU YAHOO!?
Frank:
Are you asking what to use or how long to make it??
Paul Bartz
Sent: Monday, February 22, 1999 2:08 AM
Subject: Re: GMC: Piston Rod Master Cylinder----Booster
Changed to 85 Chev =BE ton that has the 13" rear drums. The reason for =
the
longer rod. The support bracket has to be between the Booster and the
Master Cylinder for clearance reasons. This moved the master cylinder =
1/8"
further out. Thus the longer rod..............Frank
Date: Sun, 21 Feb 1999 17:03:03 -0800 (PST)
Paul
Herm
Frank Folkmann
wrote:
I need to increase the length of the piston rod between the Master =
Cylinder
and Power Booster by 1/8". The installation of a different master =
cylinder
and the positioning of the support bracket will necessitate this =
change. Any
Frank:
Surprised you didn't talk to Bobby. He did his. All you need to obtain is
rod stock approximately the size of the original or a little larger. A
machine shop can help you.
Paul
Sent: Monday, February 22, 1999 11:00 AM
Subject: RE: GMC: Piston Rod Master Cylinder----Booster
Paul.
Have to make it 1/8 longer. What can I use?..............Frank
Date: Mon, 22 Feb 1999 10:25:13 -0500
Frank:
Changed to 85 Chev 3/4 ton that has the 13" rear drums. The reason for the
Master Cylinder for clearance reasons. This moved the master cylinder 1/8"
