What I see from your video is three items that need attention.
1. The pinion may have lost the bearing preload, which can cause tooth chip, the pinion seal and trans
seal to leak oil from the weep hole, and it could also brake the tail end of the trans output shaft.
From the look of the pinion ring tooth wipe, the pinion should be a little deeper to center the wipe
on the ring gear, pinion preload may take care of that.
2. As is the the ring gear has too much backlash (0.004 to 0.006), the pinion input wobble (loss of preload)
could be a cause of the increased backlash and tooth chip.
3. The ring gear tooth chips are not a cause for replacement (IMO). With a small grinder dress up any sharp
edges, they are on the load side of the tooth. If the pinion has also chipped tooth, it could change the
equation.
The service manual has the settings.
Adrien & Jenny Genesoto
75 Glenbrook (26-3) Mods LS3.70 FD / Reaction Sys / 80mm Front&Intermidiate / Hydroboost / 16" Tires / Frame Rebuild / Interior Rebuild
Yuba City,Ca. Text 530-nine-3-three-3-nine-nine-6
equation.
