Bob, the EL II compressor/desiccant assembly was state of the art stuff
when they were used in the late 77 and 78 coaches. There are two weak
points (times two) The first one is the permanent magnet fields in the
motors. They fade away over time, and not much the average owner can do
about it. The motors just develop less and less torque as they age out.
Newer permanent magnets use some rare earth elements, and retain their
strength for many years. Like the ones used in the Vi-Air compressors. Get
a screwdriver near the motor and they will stick right to them.
The second weak point is the exhaust valves built into the compressor
cylinder head(s) They are not servicible and are a common source of air
leaks. Not much can be done for them, except, like Cinabar and some others
have done, add a downstream solenoid controlled valve. More complexity to
an already complex system. Not the way I like to go. I subscribe to the
K.I.S.S. principle. The least complex system USUALLY winds up being the
most reliable.
Both of those weaknesses I described are resolved by replacement of the
compressors, or a complex workaround. Compressors SIMILAR TO, but not
exactly the same, we're used in a number of Oldsmobile Silouette vans, as
well as Pontiac and chev vans that share the platform with Olds. No current
production vehicles that I am aware of use an exact replacement compressor.
Rotsa Ruck finding something. Same for the height control valves. Some are
close to the same, but not exact. They can be improvised to work. I have a
bunch of pieces for the EL II. Let me know if I can help you with used
parts. Shipping costs.
Bob - any other good parts on that '78 salvage coach?
Steve Southworth
Palmyra WI
