Unless you remove and then re-fit the fan shroud and its mounting plate. Then if you don't check the clearance between the pickup
and the magnet the flywheel can hot the pickup. Yep, been there, done that!
Regards,
Rob M.
Sydney, Australia
-----Original Message-----
From: Gmclist [mailto:gmclist-bounces] On Behalf Of James Hupy
Sent: Thursday, July 13, 2017 9:20 AM
Subject: Re: [GMCnet] Pertronics and Onan8h
Once the flywheel is modified with the addition of the magnet, and the
pickup coil bracket is mounted, the ignition timing will not change from
that setting.
With ignition points, the ignition timing will change as the points
plunger wears. Not a good thing.
