PermaCool Tranny cooler
dick kennedy
181
Heinz
Do you have the meters to measure the temperature drop across the cooler
and the flow through it. If I was doing it I would attach thermocouples at
various points to try to make sense of it.
Of course it's much easier to talk about it here in the cheering section
than it is to do it so keep talking to us.
Dick
>FWIW... as it turns out it takes quite an imagination to call it a cooler.
>In Medford I changed it to in front of the crossmember with 60 percent
plus free and clear in full airflow and fan mounted to push air through the
device. ( I refuse to call it a cooler any longer).
>i went out over the ashland hill and temps hit 260 in the pan as well as
in tranny outlet. Only for a short time, but I didn't like it nevertheless.
Interesting that temps were the same as in no cooling whatsoever?
>Thank goodness I bought a Hayden cooler at the Medfodr NAPA as a just in
case.
>I installed that at the rest area between the hills and the rest was much
more pleasant.
>The diff is that the MaxiCool has fins surrounding a pipe while the Hayden
is a miniture radiator as in 'cored'.
>I installed it in series as it was easier for the time being but with the
Hayden in the temp went up when I was pushing hard uphill and then down
again. Seems the Maxi only delayed getting hot some as in temp would
increase until no longer tolerable instead of up and down.
>Currently in Redding, CA. Changed tranny fluid and reconnected the
external filter to see what it'll do. Normal tranny out temp with the
hayden was about 180/190 +/- so the thermostat may be right yet, it's just
the cooler (oops) that was never able to bring the temp down.
>If tomorrow goes ok I'm going to put it back on for the northbound trip
(thermostat).
>It's been a doozer... but still moving. No luck getting pads and calipers
today. Only oaccasional noise today when brakes applied. I think I have it
down to the front right so it'll come off first as soon as I have pads and
caliper.
>Heinz
>...napping in Redding CA.
>BTW, with the raybestos MC the brakes went soft a few times under hard
usage. Since the GM one is in pedal is solid.
