pergo flooring
james ross
21
greetings all:
I am considering putting pergo flooring (prefinished wood) where the
lino is in my '76 Edgemont. ( with the seperate shower. We didn't use it
until last year where the campground shower was too far away. I thought
it was wonderful!) Any advice / concerns re: this type of flooring in
the coach? This is supposed to be a floating floor, whatever that is,
and you have to bolt the seats and seat belts down through it. Any
problems with that?
Cheers.
Jim Ross
A Floating Floor like Pergo has a thin sheet of plastic foam like material
under it. The flooring is glued together at the end and edges of each piece.
The flooring is only held down by the floor trim on the outside edge on
walls. There is no connection with the sub floor.We have that in our
downstairs room I helped install 1,200 ft. of similar flooring just a
different name brand.
Marlene Meineken
To: motorhome mailing list replies
Sent: Thursday, April 20, 2000 11:58 AM
Subject: GMC: pergo flooring
> problems with that?
> Cheers.
> Jim Ross
