When checking the inside of the tanks besure to use a mirror and check the
inside top of the tank. That is where my rust was at as the bottom of the
tank looked clean. Jim Huppy was the guy that pointed it out to me.
On Mon, Dec 21, 2020 at 3:26 PM Greg Crawford via Gmclist <
> I wholeheartedly agree with Matt about how to go about changing the filter.
> I brought my new coach 1000 miles back from Texas in July. It had water
> in the fuel, and several folks suggested changing the carb filter. I bought
> one, but then the coach decided it would run mostly fine with enough Heet
> in it that I did not try to change it. When I got home, I polished (diesel
> boat term) the fuel by draining it all and pumping it through a
> filter/water separator with an external electric pump. So then it was time
> to change
> that filter. It had been stripped and JB Welded in. If I had tried to
> change it on the road, I'd have been screwed as it just fell out in pieces
> when
> I put a wrench to it.
> Chuck Boyd had a 78 parts coach and sold me another carb.
> At least three companies I have found will drill and helicoil a stripped
> out carb body so it can be salvaged.
> I bought one of the thread repair fittings Matt spoke of. Basically, it is
> just a standard filter housing with four slots milled in the threads so it
> will recut the stripped threads in the body. In my case,
> there were not enough threads remaining for it to work, so I plan on
> shipping it off and having it helicoiled by someone who has the tools and
> expertise to do it right.
> Take five minutes and pull the carb off the intake as suggested so that
> you can reinsert the filter assembly by hand and you won't strip the
> threads.
> Greg Crawford
> KM4ZCR
> Knoxville, TN
> "Ruby Sue"
> 1977 Royale
> Rear Bath
> 403 Engine
> American Eagle Wheels
> Early Version Alex Sirum Quad bags
Bruce Hart
1976 Palm Beach
Milliken, Co
GMC=Got More Class
