9 to 5 also includes the fuse on the control board in rlyhe circuit. So if it doesn’t run be sure to check the fuse
Frederick CO
> Jump terminal 5 to 9. If it runs then, yes, you probably need work on the
> board.
> bdub
>> Put both tanks in that had no gas. Put 5 gals in. That took care of my
>> short test drive. Don't think that there's enough gas to have the Onan gas
>> pickup tube in the gas supply. So I filled the carb float bowl. By using a
>> squeeze bottle to the gas line to the carb. The 4000 watt Owan started up
>> right away. But stopped when I removed my finger from the start switch.
>> Ran a jumper wire from the battery. To the coil. Runs, and puts out 110
>> Volts. I know my way around the Onan engine. But the circuit board. That's
>> another story. The circuit board is $150. But it appears to me. That is
>> what I need. RIGHT? Bob Dunahugh
