Overhead cabinets
david l greenberg
8,798
1
The best advice I was ever given regarding the reinstallation of over
head cabinets (probably from Jim Bounds) is to replace the bolts with
threaded studs so when you go to lift the cabinets you can locate the
studs easier than trying to hold up the cabinets while you try to align
holes.
You can literally hang the cabinets on the studs while you tighten down
the nuts.
David Lee Greenberg
GMC Motorhome Registry
200 MacFarlane Drive
Delray Beach, FL 33483-6829
Snip...............
>us any more details? Did you jamb nut the back sides of the studs?
>Do you put the cabinet on the sidewall studs first then the ceiling
>ones or vice versa? I sure would like to hear more. It was not fun
>trying to put the back ones up. Thats what I want to know more about.
>Take Care
>Arch 76 GB IL
>In a message dated 2/22/99 5:11:51 PM Central Standard Time,
Yes, Jam nut the studs into the wall. That should help to locate the top
for the ceiling bolts.
>over
>with
>the
>align
>> holes.
David Lee Greenberg
Boston Homes, Inc
1220 US Highway 1, Suite B
North Palm Beach, FL 33408
T:561-776-1414 F:561-776-1788
