Overhead Cabinet
hemogoblin
138
Hi All,
Anybody out there have an over couch (driver side) cabinet they want to
sell? I'm looking for the LOUVERED door, late Palm Beach model. Additionally
does anyone know of a source for replacment fasteners for the engine inside
hatch covers, I'm referring to those items at the step edge of the hatch,
both parts.
Mark '77 Palm Beach LINY
I am also looking for the "keep nuts" for the hatch cover
gene
>Hi All,
>both parts.
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
Good idea buy I need the nuts that are in the frame that the bolts screw
into. I broke both of mine while working on the TBI ;>(
gene
>gene >>
>Gene - if by "keep nuts" you mean the small clips that keep the screw pins
>from pulling out when you lift up on the pins, I found a solution many years
>ago. I found that a 1/4" lock washer could be bent open slightly to fit on
>the pins and then closed with pliers. It worked fine and it is much
stronger
>than the little "keep nuts" originally used by GMC.
>Emery Stora
>77 Kingsley
>Santa Fe, NM
mr.erf
Additionally
If you don't find the cabinets, what some people have done and we are
planning
on doing is to move the two cabinets from the bedroom and then have others
(possibly larger) built for the bedroom.
Kara Kosier
77 EII
