Overbore Size
Carl Stouffer
4,692
380
83
Tucson, Arizona 85718
Long story, but I have a full reciprocating assembly that I acquired from Steve Ferguson, that HE got from another GMCer who received it as part of a
warranty settlement from Mondello. The only problem is that (I believe) it has .060 over pistons and rings. I am looking for opinions on whether or
not this much of an overbore is an issue on a 455. If it is even questionable, I will try to work out some kind of a deal on those parts and go with
about a .030 overbore.
Carl Stouffer
'75 ex Palm Beach
Tucson, AZ.
.060" is OK on the 455. .030" on the 403. If in doubt, have a sonogram
done on the block. Probably not a bad idea in any event.
Salem, Or.
> go with
> Carl Stouffer
> '75 ex Palm Beach
> Tucson, AZ.
> Eagles,
On a LOT of engines 0.060" is probably over the RECCOMMENDED maximum.
Ken H. knows some engine people that could probably give a very educated opinion.
0.060" might work on a particular block but not on another of the same type/brand, etc.
Core shift.
Ken H's friend might also be willing to tell us about "core shift"
DAVE KING
lurker, wannabe
Toronto, Ontario, Canada
Dave,
You are not that far from Dick Paterson up in Coldwater, ONT. You can reach him at 705 325-4554. He is the go to person on the 455 engine and the 403 too.
J.R. Wright
GMC GreatLakerTech Editor
78 Buskirk 30' Stretch
75 Avion Under Reconstruction
Michigan
> Core shift.
> DAVE KING
> lurker, wannabe
It's worth the time to contact people like Dick Patterson as he is familiar with the 455/403
Sent from my iPhone
> Dave,
> J.R. Wright
> Michigan
>> Core shift.
>> DAVE KING
>> lurker, wannabe
Keep in mind that .060" is only .030" on each side. Less than 1/32". The
455 is an "OLD SCHOOL" engine. SMALL bore, LOOONG stroke. Lots of meat
around the cylinders, and a really good casting with high nickel content.
Not much problem with "core shift" in these engines compared to "modern"
engines like 350 chev. Don't believe me? Ask Dick Paterson.
with the 455/403
Sent from my iPhone
> Dave,
the 403 too.
> J.R. Wright
> Michigan
opinion.
type/brand, etc.
>> Core shift.
>> DAVE KING
>> lurker, wannabe
.060 over is somewhat common. The only real down side is that it can't be bored again. In a motorhome. You'll never live long enough to have that as an issue. Bob Dunahugh
With the amount of work it takes to R and R an engine in a TZE, I would not want a + .060 in mine when pulling a long long grade over 6%.
I would put a meatier block in the MH and use that one in a Cutlass, 442, or 98 where long term heat loads are much lower.
John, you are certainly entitled to your opinion. Spend your money however
you see fit.
I have a 10k engine that runs great so hopefully I won't be spending any money on it at all!
