Outdoor Shower Ideas
steve averill
9
I've been thinking about adding an outdoor shower to my GMC with wet side
bath. I haven't seen any threads from people that have done this, but it
seems there are several ways to do one & I'd be interested in thoughts from
people on the list. In increasing levels of complexity (I think) are:
* Run a tee from the existing shower head - this has the advantages of
being relatively freeze resistant, but it'd take two people to get the
temperature right.
* Run a tee from the kitchen sink - this might actually be simpler than the
first method, but one MIGHT be able to do it single handed via the window.
Probably a two person job. One disadvantage is it's on the "back side" of
the coach.
* Run hot and cold lines to the refrigerator compartment and then put in a
control. To take a shower, just open up the door & work the controls. The
disadvantages to this are susceptibility to cold, reduced cooling from the
fridge, and the possibility of a plumbing failure messing up the expensive
refrigerator.
* Plumb off into the propane compartment and put controls in there. It's a
fairly simple run, but the controls would be a bit low. The other
disadvantage is it gets pretty cold in there in the winter.
* Plumb through the bath wall with hot and cold into the GFCI door & remove
all the GFCI outlet electrical (I don't use it anyway - why bother when you
can use the campground 20 amp outlet?). That'd have the advantage of being
pretty easy to insulate & using an existing door at a convenient height.
It'd have the disadvantage of being a lot of work & losing the GFCI in case
I ever wanted it.
* Plumb through the bath wall & put in a new door. Disadvantages as above
but with the added problem of matching paint and getting the new door &
getting it keyed like the other doors.
-Steve A.
>Steve, I have a shower on the ouside of our coach. Its on the driver side.
>Bought at Camping World some time ago. Use it for rinsing feet and diving
>gear mostly.
>Mine is teed off from the shower head. Works well.
Manny
Looking forward to seeing it. Let us know who is posting it or if you
could, send direct....
Thanks
MikeBeaton
Antigonish NS
> Steve, I took a couple a pictures and sent them to you. If someone else is
> interested on what it looks like AND someone wants to post it on their site,
> I will comply.
> Manny Trovao
> 73 Custom/ex-Glacier
> In a message dated 6/17/99 10:23:11 PM Pacific Daylight Time,
> Camping World added or is it via a pre-existing door? Is it a simple tee
> off the shower head (no outside control of temperature) or is it
> temperature controlled from the outside? >>
