I don’t have an oven like that anymore. Replaced with a microwave and top burners.
If I recall the door had an inner panel and an outer panel with a stainless channel around the outside.
There must be screws holding it together. You might have to take the dot off to get it apart.
Emery
> Emory,
> How does that inner panel remove? Is it just the one side and can it be
> done with the range in the coach or should I remove the unit for easier
> access?
> Thanks
> Fay
>> On Sat, May 16, 2020 at 4:47 PM Emery Stora via Gmclist <
>> Hi Faye
>> I suspect that you have a loose bolt. If you remove the inner panel you
>> can get to the hinge and see what is wrong. If you can’t fix it let me
>> know. I might be ably to find a door for you.
>> Emery Stora
>>> On May 16, 2020, at 5:40 PM, Burt and Faye curtis via Gmclist <
>>> I am having am ongoing problem with my original oven door. The right
>> hinge
>>> went hinky and though I can sometimes coax it kind of back into place, as
>>> soon as it is opened again, it is out of wack, preventing it from
>> closing.
>>> Yeah, I know this is sort of an unclear description, but does anyone know
>>> how to correctly fix this problem? Hate to discard a unit that is
>> otherwise
>>> working.
>>> Thanks in advance,
>>> Fay Curtis
>>> '76 Glenbrook
>>> Kneeland, CA
>>> _______________________________________________
>>> GMCnet mailing list
>>> Unsubscribe or Change List Options:
>> GMCnet mailing list
