Operations manual?
gene
2,215
manuals
http://www.california.com/~eagle/brochure.htm
gene
>We have a maintenance manual and a parts manual (74/75) but were wondering
if
>there was an actual operations manual. Our was a 75 transmode, but shouldn't
>there be something? We presently have it in our driveway which is on a
fairly
>steep hill and the airbags don't seem to be doing much. We are not sure if
>the power level works and how much they compensate for slope. They could be
>inoperable for all we know. We are taking it in to the shop on Thursday to
>have them go over it. Also, the speaker plate above the driver's door is
>broken and we found it in the parts cataglogue. Does Cinnabar handle the
same
>parts with the same numbers? Also, how do we find the interior color? Thanks
>you guys! Susan
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
Susan,
That's a lot of questions. I'll try to give you some insight on one. The
auto position of the leveling system doesn't really level. Each airbag has
a sensor in its wheel well that is anchored to the body on one side and the
bogey on the other. When in the "auto" position, it serves to keep the
distance between the bogey and frame the same distance apart regardless of
load. Thus if you are parked on a non level surface, it will not
automatically level the coach. You must do it yourself using the manual
raise/lower switches.
Do you have a drivers door?
Bob McLaughlin
- -----Original Message-----
[mailto:owner-gmcmotorhome]On Behalf Of
Nuevomex
Sent: Saturday, July 01, 2000 6:50 PM
To: gmcmotorhome
Subject: GMC: Operations manual?
if
fairly
same
you guys! Susan
> Nuevomex
> To: gmcmotorhome
> wondering if there was an actual operations manual. Our was a 75
transmode, but
> shouldn't there be something?
As far as I know manuals were not provided with Transmodes. It was up to
the upfitter to prepare them and I believe most of them did.
The Transmodes were all shipped white on the exterior but they were
shells only-No windows and no interiors.
David Lee Greenberg
The GMC Motorhome Registry
Dedicated To The Preservation of the Classic GMC Motorhome
http://www.GMCss.com/Registry.htm
http://www.Buskirk-RushRV/GMC-Registry/online-registry.htm
