Eric,
Sorry for the late reply - I got my valences from Jim Bounds (CoOp), they
are white plastic, 1/8" thick, 2.5"
x2.5". It could be something that's used
in construction, or maybe packing - I don't know where he gets them from. I
bought them "pre-cut" (one side of the "L" is cut down to about 1.4" at the
top and bottom and curved to fit the walls), I had to do a little sanding
but they come pretty much ready to install with all the hardware (aluminum L
brackets, rivets and screws). The plastic is really easy to work with, you
can also make your own template and cut them out yourself with a jigsaw.
We glued the fabric to the valances with 3M spray adhesive.
Let me know if you have any more questions!
Peter
Colorado
To:
Sent: Tuesday, June 06, 2000 8:51 AM
Subject: RE: GMC: OOOPS! --Valence Job
> Peter
> I am in the process of redesigning my valences. What base material did
> you use? Several people have suggested plastic downspout. Is this the
> direction you went or did you use 1/4" plywood or plastic?
> Eric Tipton
> etipton
> -----Original Message-----
> From: Peter Brandt [mailto:schaf]
> Sent: Tuesday, June 06, 2000 7:21 AM
> To: gmcmotorhome
> Subject: Re: GMC: OOOPS! --Valence Job
> Richard,
> Thanks - I attached the short piece of the valance to the bunk bed arm
> with
> a single rivet. As you know there isn't much clearance between that
> "arm"
> and the wall, so it's a tight fit for the blind back there. Spacers
> might
> help. I don't think we'll use the bunk bed a lot, but I wanted it to be
> useable, just in case.
> Peter
> 77 Eleganza II
> Colorado
> From: "Richard Waters"
> To:
> Sent: Monday, June 05, 2000 7:41 AM
> > Peter,
> > Nice job on the valences!
> > I finished the living area valances about a month ago. As you know
> > doing the left valance by the bunk was a challenge. In mine I cut the
> > valance out on the bottom to follow the contour of the bunk bracket.
> > That turned out sort of OK. I saw that in Mike Beaton's coach. Your
> > solution looks nice and neat. I don't really like the way mine turned
> > out. I might redo it and copy yours.
> > Richard Waters
> > '76 PB, Troy, MI
> > > Sorry, forgot the link:
http://albums.photopoint.com/j/AlbumList?u=180485
> > > It's way past my bedtime again!
> > > Peter
> > > 77 Eleganza II
> > > Colorado
