One ton inner CV boot
hal stclair
923
Anyone have the number for the inner CV boot from a Manny one ton?
Thanks for any help.
Hal
1977 Royale 101348,
1975 Eleganza II, 101230
1974 Eagle Bus 45',w/slideout
Hal,
I've got a couple of spares; I'll try to remember to check them for numbers
tomorrow.
However, a good application guess would be a 96 Chevy 3/4 t. Suburban 4wd.
On Wed, May 10, 2017 at 9:52 PM, Hal StClair
> Hal
> 1977 Royale 101348,
Hal,
The boots I have from Manny are Interparts BT-257. For most GM
applications, that's specified as Inner; for some, Outer. Without being
able to check the numbers on the boots installed on Manny's axles, they
appear to be the same at each end. Interparts has a PDF on Google for
their boots.
> Hal
Thank you for the numbers Ken. Interparts aren't common around here but are a better fit for the reduced clearance outboard CV. They are a little
smaller OD and clear the ball joint bolts a little better. I picked up a Moog 9470 which is listed for both sides/ends. Should know later today how it
works.
Thank you again. Hal
1977 Royale 101348,
