Have you thought about a Mighty Vac to bleed your brakes. You just have to
remember to check the level in the master cylinder.
https://www.tooldiscounter.com/product/mityvac-automotive-tune-up-and-brake-bleeding-kit-mitmv8000?msclkid=0511d160b2f5158aaf018e62e005b21b
On Sun, Jul 5, 2020 at 2:04 PM Carl Stouffer via Gmclist <
> Since a speed bleeder is basically a replacement bleeder screw with a
> check valve in it, I don't see how that could hurt. Once they are closed,
> they
> are the same as a standard bleeder screw.
> I have them on my '53 Jeep and the only problem I have experienced with
> them is that they tend to plug up tight from disuse, so they might not do
> what
> you want them to do when you need to bleed the brakes.
> Carl Stouffer
> '75 ex Palm Beach
> Tucson, AZ.
> Chuck Aulgur Reaction Arm Disc Brakes, Quadrabags, 3.70 LSD final drive,
> Lenzi knuckles/hubs, Dodge Truck 16" X 8" front wheels, Rear American
> Eagles,
> Solar battery charging. GMCSJ and GMCMI member
Bruce Hart
1976 Palm Beach
Milliken, Co
GMC=Got More Class
