Onao Air Filter
gene
2,215
similar price but washable
Washable/Hi Flow Air Filters are available from K&N Company
that fit our Onan Generator set as follows:
mfg: K&N Company
size: 3 different heights (measure yours to place
order)
4 KW Onan has Air Filter 2" dia. & 7" Height
6 KW Onan has Air Filter 3" dia. & 6" Height
Contact 1-800-851-5334 (Direct Buy-Allison
Enterprisers)
Cost: Approx. $25
gene
>Is the 140-1229 air filter shown at GMCMart the only thing that will fit?
>Mine has a filter that is about 7 inches long and about 3" in diameter. The
>price shown on GMCMart is over $26!!!!!!!!! Sounds awful high for such a
>little filter!
>David
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
> little filter!
> David
Only $26 ? The Cummins/Onan dealer here (eastern Canada) wanted $54 and a FEW
weeks to get it! I did a lot of searching and came up with this: CarQuest #
87722 .
It is shorter but the same diameter. I carefully cut the bottom off the
original filter and
shortened the threaded rod by the appropriate length. It has worked well for
me.
I forget the price but $54 worth of these will last me and my onan well past
retirement.
( a very long time )
Dan Vanderknaap
(Sydney N.S or bust friday night!)
Dan
Someone once suggested I wrap thick foam around the filter as a
way to prolong it's life. Remove foam regularly and save the
"expensive" one from getting dirty. After blowing it out, re-install.
Re: Friday. I may or may not be home(may ignite the Travelin'
Bear for a little work out). If I am, cold ones are available. If I'm
not, try me on the way back.
Problems in the Antigonish area...Henry's Esso in Lower South
River.....
See ya
Mikeb
> > little filter!
> > David
> 87722 .
> original filter and
> me.
> retirement.
> Dan Vanderknaap
> 76 Palm Beach
> River.....
> See ya
> Mikeb
Mike,
Thanks for the invitation. I plan to pick up friends in Amherst around 5:30pm and be
in
Sydney by midnight so we probably won't be making too many stops(I hope).
If the ground quakes and the windows rattle sometime that evening don't be alarmed,
it's just a Palm Beach at speed ! Just had carb rebuilt and installed full 3"
exhaust with
a single FloPro muffler at rear. It's a bit loud, but boy does it work (g). Maybe a
contender for the LSR (vbg).
Anyway I will try you on the way back through.
Dan Vanderknaap
may have to let some air out of the rear to keep that baby on the ground at
speed. Way to go.
gene
>> River.....
>> See ya
>> Mikeb
>Mike,
5:30pm and be
>in
alarmed,
>exhaust with
(g). Maybe a
>Dan Vanderknaap
>76 Palm Beach
mr.erf
