Onan
Melbo
Member
Aug 19, 2018
155
10
18
75
I am fairly knowledgeable about electric systems. My onan runs fine. Just put a new board and pertronix ignition in. Had it running and plugged in
the electric supply for the panel inside the coach. Went in and turned on the breakers. The ac started and was playing with the controls and
everything quit. Now I only get 7 volts at the outlet and about the same at the breaker on top of the onan when I test it to ground. My guess is the
bridge rectifier but I thought that I would draw on the knowledge base here to see what the consensus is. Any thoughts or other things that should be
checked would be greatly appreciated.
Thanks in advance
Melbo
That definitely the first to look. The board has nothing to do with generating power so leave it and the Pertronix alone.
If the full wave bridge rectifier is not bad, them you need to ohm meter the (non-rotating) field. The value is in the manual. I forgot what it is
suppose to be. Get one locally. They are cheap for a 1000 volt one.
You will not find one that has the same orientation of the mail plugs so
you'll need to drill out the nylon plug holder and then attach the plugs.
The original rectifiers does not hold up like the new that Ken Burton
suggested.
On Tue, Dec 3, 2019 at 9:01 PM Ken Burton via Gmclist <
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
I bought one of the new RB's and bent the pins to match the plug.
First shot did't work.
Rotated 180 deg and all is good.
one must keep track of the positive position, as it will not work otherwise.
On Tue, Dec 3, 2019 at 9:27 PM Mike Hamm via Gmclist <
Thanks for the help with this. I got a bridge rectifier locally and got it installed. I did it wrong a couple of times but finally figured it out
and now it is working fine.
Melbo
Super!!
I have been told that shutting down the generator under load can cause this failure. I do not know this from my own experience, but I always turn off
everything that is high load like the AC or water heater BEFORE shutting down the generator.
Someone tell me I am wrong and why. I'm listening.
The new Bridge Rectifiers should be capable of considerable more abuse.
Worth the hassle to change at home than on the road.
On Sat, Dec 7, 2019 at 2:10 PM melmull--- via Gmclist <
> Melbo
Bob, I believe, as did Dwayne Simmons and several others, that you are 100%
correct. Turning off ALL loads on the generator before shutting it down, is
the correct way to do it.
On Sat, Dec 7, 2019, 6:59 PM Ken Burton via Gmclist
wrote:
> Super!!
> off
> down the generator.
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
The under load shutoff failure appears with the OEM rectifiers, which had questionable revers voltage ability, and questionable current capacity. As
the engine slows at shutoff, if there's a load it will draw enough current to increase the voltage on the compounding reactor that it may spike
beyond the reverse voltage rating of the rectifier which then shorts and almost instantly burns open... At least that's my take on it - the symptom
is the rectifier goes Dixie all at once. 1KV 30 Amp or so rectifier bridges are cheap on eBay and the overkill in spec doesn't hurt a thing.
Shutting down under load may do dirt to some of the things turned on but shouldn't bother a higher rated bridge.
There are 16 discrete ways to connect the thing, only 1 will work. Note which wire goes where >before< you remove it because the blades on the new
one are not oriented the same. I make 4 male to female jumpers a half inch or so long and plug the females on the new bridge, males in the existing
[plug.
> Super!!
> off everything that is high load like the AC or water heater BEFORE shutting down the generator.
Ken,
After mine blew out at an inconvenient time because the control board failed a solder joint, I though to figure out why and how to prevent it.
(Short aside note: A BF (4Kw) unit in a 23 cannot be pulled out far enough to access the bridge.... BTDT)
Being a hair-ball engineer, I got out a package of software that was copied from the inventory of a former employer and modeled the system as best I
could with no real measured values except what I could infer from the test setup in the Onan manaul.
I modeled the rotating armature as half a transformer because I couldn't figure out how to spin the computer. I made the shutdown by just opening the
supply to the primary. For a simple system, it sure does go berserk.
After several runs as various settings, I got the system to spike to about 300 volts to the field winding. For a system designed with a field voltage
of about 50 Volts and in the day, higher PIVs cost more money, I bet that the rating of the bridge is not all that high. This was all with just a
resistive load and a little inductive to make a PF of 0.8.
If I knew where to get a hold of a curve tracer and an original part, it would be fun to know.
I am not completely sure why I bothered, but I know the higher PIV bridge that I put in has never had any problem.
Hi Matt,
I have never needed to replace mine but I have carried a couple of spares for years and installed a few on other peoples Onans. I also never turn
mine off under load and Laurie knows that she is in deep dodo if she does it wrong.
Now that I said that, it will probably blow the next time I use it.
Mine failed when the main tank level dropped too far with both roof air on. Yes as RPM drops the output voltage drops so the bridge and reactor try
to compensate by sending more to the field. This would happen during start under load as well. I always start Onan no load, let it warm at least 30
seconds before applying load On shut down I remove load and run at least 60 seconds to let Onan dissipate working heat before shut down. Longer if
very hot out. Some have been ok Not doing this but I don't think it's good practice. Same as with a horse, you warm up, work, cool down, put away.
