Scott
Found this which might be interesting in the archives:
Date: Tue, 11 Aug 1998 16:46:43 EDT
Subject: GMC: Onan generator bridge rectifier
New to this net, hope this info is not redundant.
My Onan 6KW generator stopped producing 120 volt power. Per the repair
manuals, I found my bridge rectifier to be bad. Onan, and Onan distributors
sell their replacement part for about $30. Being a electrical nut I figured I
could find a cross referenced part directly from a major semiconductor
supplier much cheaper. The number on the part didn't cross directly, but I
found an equivalent part (physically) with reasonable voltage and current
values from Mouser Electronics (800-346-6873) for about $6. They are a great
company that has no minimum order, same day shipping and doesn't mind retail
folks like us. The part number is 583-MP354. Or just tell them you want a 35
amp single phase Bridge Rectifier.
The catch. The male tab connectors are oriented somewhat differently. I
removed the tab connectors from the nylon connector holder and hooked them up
directly, and used a bolt and nut to reattach the part vs the self tapping
screw that held the nylon connector thingy. About a 5 minute job with a VERY
small screwdriver.
If you can't deal with the "catch" then order an NTE5342 (a NTE5340 should
also work). Also available from Mouser, but they have to order it also and it
will take an extra week or so, and it'll be about $10 or so. That part should
match EXACTLY.
If you live in a large city, the NTE number will cross to whatever some local
supplier will have in stock usually.
Mike Danford (judyd)
1977 Palm Beach
Hope this helps
bdub
>In a message dated 5/1/99 6:27:08 PM Eastern Daylight Time,
>> If so, does anyone have any numbers off one?
>Hi Rick!
>Normally I read the numbers off the old bearing and get the replacement
>however since I used heat and the bearing was quite rusty, no numbers could
>be read! Now we have some numbers to use.
>The bridge rectifier is approx 1 3/32 x 1 3/32 and has Initials MS and the #
>305-0517
>this part was also from Onan.
>Scott
http://www.pituitary.com/ t=_self]PTNA Home Page[/url]
http://smsgmc.webjump.com t=_self]Zak's Project[/url]
