Onan
chuck will
479
What is a normal life span for the Onan Genset? Mine has almost 700
total hours on it. Chuck in Lompoc
That is low hours and if you have serviced it right should get many more.
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
Mine has 7,000 hours on it and I expect it to go any day....but, it
starts, runs AND makes 60 Hrtz electric.>
David Lee Greenberg F22009
GMC Motorhome Registry
200 MacFarlane Drive PH4
Delray Beach, FL 33483-6829
Dan-
Mine did exactly the same thing. Real exciting when it happened first
time and I had just gotten out of the shower!!!
I had the unit serviced and they said that they found the solenoid
gear/shaft was loaded with dry, hard grease. Once that was removed and
cleaned up it works just fine now. Probably was the original lubricant
that had gotten hard and dirty with age. Suggest you pull the starter
and solenoid and take a look.
Gary
'77 Kingsley
North Bend, Oregon Coast
