Onan
chuck blanford
296
Don't overlook the obvious - is the 50 amp shore power cable plugged into
the coach receptacle?
cb
> From: Frank Folkmann
> To: gmcmotorhome
> Subject: GMC: Onan
> Date: Wednesday, November 04, 1998 6:36 PM
> TW
> I have the same problem. No AC. Have checked breaker, rectifier and
> fuse on controlboard. All are OK but no Ac. HELP HELP HELP.
> Frank Princeton IN TOYOTA LAND
> ______________________________________________________
> Get Your Private, Free Email at http://www.hotmail.com
Is this with the Hard power as well as the Onan Generator? If this is
the case you may have a bad switch in the switching system. Don't open
it and start jiggling things around while you are hooked up or the
generator is running it could prove to be fatal. But you could check
continuity to see if the switch is working properly. Chuck
> TW
The start button quit working on the generator the other day for no
apparent reason. I figured it was something stupid since I didn't know
anything about it except that it's suppose to start with that button.
Well, I just went out found it wasn't getting any gas at all. So I started
tracing out the line and, lo and behold, it went straight to the propane
tank!
Hmmm, ok. So I turned on the propane and it works like a charm. But after
a while, it just died for no apparent reason. Now, it seems like I was
told by someone to only run the genset when it had a load on it. I managed
to get it cranked back up after a while and it was coughing so I turned on
both the roof air conditioners and the fridge on 110. It's been running
for about 30 minutes now without even a shimmy. Could someone explain this
to me?
I figured it would take a while to charge up the house battery since it was
completely discharged and wouldn't crank the genset. Wouldn't that be
enough of a load for it?
Thanks
bdub Billy Massey
Life in th' Slow Lane bmassey
Lake Brownwood, Texas http://www.web-access.net/~bmassey/
--'76 Palm Beach-- http://wwp.mirabilis.com/202333
>Billy - sounds like some retroverted to propane. You should never start up
>your generator with a load on it. Turn off the A/C and other high current
>machinery. Some people turn off their main breakers so there is no load.
>Once it is started you can turn on equipment.
I didn't turn on anything till it started and then sounded like it was
gonna die again.
>I don't think there is any problem running with no load. When mine is in
>storage I start it up and let it run for about 30 minutes. Been doing this
>for years with no problem.
This one ran smooth as silk for about 20 minutes, then sputtered and died.
>The problem you are having seems to be when the engine is cold. Perhaps the
>choke is not working properly. You indicate that once it warms up it runs
>smoothly.
Nope, it was good and warm by then.
Thanks Emory
bdub Billy Massey
I think if one were to check out the Onan guarantee it requires the genset to be
operated a minimum of one hour per month.
> smoothly.
> Emery Stora
> 77 Kingsley
> Santa Fe, NM
>in
>this
>T
>Emery Stora
>77 Kingsley
>Santa Fe, NM
I hate to be disagreeable but running no load is not recommended.
Dave Greenberg
GMC Motorhome Registry
200 MacFarlane Dr PH4
Delray Beach, FL 33483-6829
