Onan training tape (troubleshooting the PowerDrawer)
RF_Burns
Super Moderator
Staff member
Sep 7, 2008
5,155
1,357
113
Ontario Canada
Here is a link to an Onan training tape on troubleshooting the PowerDrawer generator. I'm not sure where I saw this link, but I searched here and
could not find it. It if was recently posted here, I apologize.
Its a great old video that I have never seen before on how to troubleshoot and set things like governor and carb.
https://www.youtube.com/watch?v=tJcwLyrHMq4
Bruce Hislop
ON Canada
Great video with a couple errors. The graphic has RMP instead of RPM, and at one point they mention the high speed mixture screw where it seems they
should be referring to the low speed mixture screw. They also seem to weight freq over voltage trim whereas today most find the voltage most important
to trim for.
John Lebetski
Woodstock, IL
At least they took the time to help the community.
I can appreciate the mistakes as you can see tons of that type of error on
our web site.
On Mon, Jul 15, 2019 at 6:24 AM John R. Lebetski via Gmclist <
> important
> to trim for.
> John Lebetski
> Woodstock, IL
> 77 Eleganza II
http://www.appliedgmc.com
Thanks for posting that Bruce. Added to my long list of GMC bookmarks!
Deb McWade
Logan Lake, BC, CAN
"Li'l Sister"
'77 Kingsley, 403, EBL EFI;
TZE167V101404
It's Bigger on the Inside!
I wonder if the Simpson 260 is required. I have no idea where mine is.
Ken,
I'm pretty sure I can find mine and lend it to you.....
Thanks Matt. I'll remember that if my Onan ever quits.
I just used this to tinker with my onan. at 63 hz, i'm 134v. How do you
reduce voltage, yet maintain frequency?
On Tue, Jul 16, 2019 at 12:38 AM Ken Burton via Gmclist <
> Ken Burton - N9KB
> 76 Palm Beach
> Hebron, Indiana
Slow down the engin rpm
On Sun, Jul 21, 2019 at 10:17 AM Will via Gmclist
> > Ken Burton - N9KB
> > 76 Palm Beach
> > Hebron, Indiana
It is a volts per hertz machine - they are inextricably tied together. Slow the engine down a little as JimK said.
—Jim
Jim Miller
1977 Eleganza
1977 Royale
Hamilton, OH
Do all voltage and frequency testing on ONAN generators with approximately
50% load. If it is close on frequency (50 - 60 hz) and the voltage is under
130 v ac or so, you should be fine. No load checks will always be a bit
higher. No cause for alarm where you presently are.
On Sun, Jul 21, 2019, 10:25 AM Jim Kanomata via Gmclist <
> On Sun, Jul 21, 2019 at 10:17 AM Will via Gmclist >
> > > Ken Burton - N9KB
> > > 76 Palm Beach
> > > Hebron, Indiana
> > > GMCnet mailing list
> Jim Kanomata
> jimk
> 1-800-752-7502
i'm good under load. Its the no load that is a bit high. OK. Thank you.
On Sun, Jul 21, 2019 at 1:43 PM James Hupy via Gmclist <
> Jim Hupy
> > On Sun, Jul 21, 2019 at 10:17 AM Will via Gmclist <
> gmclist
> > > > Ken Burton - N9KB
> > > > 76 Palm Beach
> > > > Hebron, Indiana
> > > > GMCnet mailing list
> > > GMCnet mailing list
> > Jim Kanomata
> > jimk
> > 1-800-752-7502
Adjust the Idle jet and the main back and forth little at a time.
On Sun, Jul 21, 2019 at 10:47 AM Will via Gmclist
> approximately
> under
> > Jim Hupy
> > gmclist
> you
> > > > > Ken Burton - N9KB
> > > > > 76 Palm Beach
> > > > > Hebron, Indiana
> > > > > GMCnet mailing list
> > > > GMCnet mailing list
> > > Jim Kanomata
> > > jimk
> > > 1-800-752-7502
> > > GMCnet mailing list
You cannot. Voltage and frequency are directly related to RPM.
I adjust my voltage to 128 v at no load. This gives me about 120 v with an aircontioner and mucrowave both running.
Emery Stora
>> Ken Burton - N9KB
>> 76 Palm Beach
>> Hebron, Indiana
>> GMCnet mailing list
Thanks all. I do the same. The video is slightly misleading in that regard,
giving preference to frequency. I will stick with voltage
On Sun, Jul 21, 2019 at 5:42 PM Emery Stora via Gmclist <
> Emery Stora
> > On Jul 21, 2019, at 11:16 AM, Will via Gmclist
> >> Ken Burton - N9KB
> >> 76 Palm Beach
> >> Hebron, Indiana
> >> GMCnet mailing list
Stick your digital volt meter into your household receptacle sometime,
morning, mid afternoon and early evening. I think you will be surprised at
the voltage variation. The frequency stays fairly constant. Some of the
more modern gensets hold voltage and frequency a bit better than the ONAN
from the 70's.
Salem, Or
On Sun, Jul 21, 2019, 5:22 PM Will via Gmclist
> > Emery Stora
> > > On Jul 21, 2019, at 11:16 AM, Will via Gmclist <
> gmclist>
> > >> Ken Burton - N9KB
> > >> 76 Palm Beach
> > >> Hebron, Indiana
> > >> GMCnet mailing list
> > > GMCnet mailing list
RV parks power supply vary a lot as they say: Flux you Asians.
Not politically correct, but I don't care.
On Sun, Jul 21, 2019 at 5:41 PM James Hupy via Gmclist <
> from the 70's.
> Jim Hupy
> Salem, Or
> regard,
> with
> > > Emery Stora
> > gmclist>
> you
> > > >> Ken Burton - N9KB
> > > >> 76 Palm Beach
> > > >> Hebron, Indiana
> > > >> GMCnet mailing list
> > > > GMCnet mailing list
> > > GMCnet mailing list
If you have a copy of the Data DVD I made. In the videos directory is that Onan video. It is one of the Dealer training videos I converted from the
slide shows they used to train the service techs. I guess someone posted it to YouTube.
Tom Lins
St Augustine, FL
77 GM Rear Twin, Dry Bath, 455, FI-Tech EFI
Manuals on DVD
http://www.bdub.net/tomlins/
