Ken,
Read the trouble shooting guide by Duane Simmons that I sent the link to.
Even if you read it slowly several times it will
Only take a few minutes. Then print it out and go out to your Onan and go
through the steps. There is no Onan issue he did not know about.
Sully
77 eleganza 2
Seattle
> > I've spent over an hour searching through multiple pages of search
> results with no luck so I will just my question straight out. When I start
> my
> > genset from either switch, it dies as soon as I release the switch. I
> know I've read about this problem before but the only thing I remember was
> it
> > will do that if it's low on oil. Mine is not so I'm left searching for
> a solution.
> > Anyone?
> > Thanks,
> > Ken
> The first thing that comes to my mind is the voltage regulator. When the
> Onan starts running, the control board gets something like 28VAC on pin 8
> from the flywheel alternator. That tells the board that the Onan is
> running. If it doesn't get that voltage, it shuts off the fuel pump and the
> ignition. A faulty voltage regulator can pull that voltage down.
> The second thing that comes to mind is the low oil pressure sender. A bad
> sender will ground pin 12 and shut it down.
> A bad control board will cause grief too.
> Common troubleshooting technique is to jumper pin 5 to pin 9. That
> bypasses the "not running" and "low oil pressure" protections. Try it and
> see if
> it continues to run. If it does, you need to figure out if it is a bad
> board, a bad voltage regulator, or a bad oil pressure sending unit. Read the
> GMCWS link posted previously to understand how to do that.
> 73 23' Sequoia 4 Sale
> 73 23' CanyonLands Parts Unit 4 Sale
> Upper Alabama
> "Highest price does not guarantee highest quality."
