There is a commercial product that eliminates the oxidation and corrosion of
terminals, plugs and electrical connections. I have a tube in my shop and
when I go there later today will get the name and mfr. It works!
>My generator has been down several times due to corrosion of various
>terminals and connectors. Since I was a kid I've always kept a jar of
>vaseline in the shop. Whenever I do electrical work I apply it to connectors
>or any other exposed copper as I assemble things. It seems to work wonders
>on minimizing future problems.
>I keep thinking that there may be a commercial product which would be nicer
>to use but the vaseline works well enough that I've never bothered to look
>for something better. It's greasiness is it's only drawback that I know of.
>Dick
>>A big *congrats*, Mark!! Happy trails & consistent 110v AC!!
>>To all: Finally worked on Onan remote start problem. Checked connector at
>>rear of Onan compartment as was mentioned, found broken wire and corroded
>>terminal. Repaired and running perfectly.
>>Thanks for all suggestions.
>>Mark '77Palm Beach
>>Hemogoblin's.com
>>As always, best regards.
>>~ Ritch & Betty Hwang ~ mailto:rhwang
>>~ =^..^= Trinket ~ the shy Persian kitty
>>~ 76 GMC Birchaven ~ RVClub 00930 ICQ# 6408591
>>(B}>
