I have been working on and off on a stubborn Onan for a year with someone. The dang starter cranks, and will not let go. Luckily he has a
disconnect on the battery.
it does not do that everytime, but most times.
Things that have been tried:
clean the switch on his onan board.(thought it got better- but was proven wrong)
I then started cannibalizing my onan, that always worked fine.....
installed the K-1 relay off my Onan. No change. - went through all the photos and wiring diagram to verify the wiring to the K-1 was
correct.(found no issue)
installed my control board - no change
installed my starter- no change. the original starter did show some corrosion, and worst shape then mine. but once we installed mine, it still ran
on.
tried to visually check the starter bracket- do not see anything wrong. Have not removed the starter bracket...
pulled the tin off, and checked the flywheel. cleaned up the teeth on the flywheel(some rust), greased the teeth and the starter teeth.
still persisting on the starter running on.
what next?
Jon Roche
75 palm beach
St. Cloud, MN
on.
what next?
Jon Roche
75 palm beach
St. Cloud, MN
