Some time back someone posted to check to make sure that the Onan
motor mounts had not sagged. If the mounts sag the starter hits the
bottom of the enclosure and reportedly breaks the starter bracket.
I checked mine and sure enough it was bouncing into the bottom
of the enclosure during the starting process.
Heinz indicated that he notched the bottom of his enclosure.
I notched the top and used washers to raise the generator mounts.
Anyhow with the motor mounts fixed now not only do I suspect
that my starter bracket might last .................but starting the Onan=
is much
less disturbing to the ears.
Regards
Gary Zingle
1973 GMC
is much
Regards
Gary Zingle
1973 GMC
