This is what Duane has kup on my web page about the starter. let me know if
it is no longer valad.
Onan Starter Information
$205 is the cost of a new Starter,not rebuilt, at my local Onan supply.
Local shops can also
rebuilt your starter at about $150. Best buy is a new starter which has a
new clutch assembly
which is not included w/rebuilt unit. Onan P/N 191-1949-03 will fit 6 & 4
KW units. Be sure
to check the mounting surface for possible interference. A slight file or
grind may be required for
proper fit. The Original starter P/N has been obsoleted & may not have a
replacement noted so
don't lose this number. Also, Ragusa Products have a heavy duty cast
steel, stronger than OEM,
starter bracket if one is needed. About 1/3 cost at Onan.Duane.
gene
>Phil Swanson,
>In reference to your call Saturday:
>I can get a remanufactured starter for the Onan for about $125 plus freight,
>with no core charge. The solenoids are $17 and the drive (bendix?) for $15.
>Plus freight of course. If you or anyone else wants any of these let me know.
>David
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
new clutch assembly
KW units. Be sure
gene
>Phil Swanson,
>David
mr.erf
