This is the Onan that I took out of the 78 that we use now. It was replaced by the Onan out of the burned 78. So I want to test run it to check it's condition. I pulled the circuit board out. Used a ohm meter to check the start switch. No continuity. Even tried a cleaner. I've identified the wire to the coil. What wire goes to the starter solenoid? What wires of the 4 that go to the remote start. Can I use? Don't mined buying a new board if it runs good. Bob Dunahugh 78 Royale Iowa
