Before you do anything drastic have you checked the fuel getting to it.
>My Onan has turned into a "Mr. Hyde" (he was the bad one, wasn't he?). It's
>almost like, over night, someone came and swiped by unit which used to purr on
>my command, and in it's place, left me with one that pops and farts and shakes
>in it's mounts. Going to do a compression check, but I already cleaned up the
>inside of the carb and replaced the carb gasket, which was open at the top.
>Looking at the points, has anyone come up with a way to work on this backwards
>facing arrangement? Could the "box" be removed from the engine and all the bad
>stuff removed and new stuff put in, then reinstall for adjustments? Some of
>you guys have figured this out, I hope. Thanks in advance. Larry Nelson, PB
>75, Springfield, MO
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
>75, Springfield, MO
Tom & Marg Warner
Vernon Center NY
1976 palmbeach
