Bruce,
I have never been into that end of an Onan, but I have designed a lot of strange stuff.
Were I you, I would call Jim Miller in Hamilton OH, and ask if he has any ideas. As he has rewound fields, he has to have seen this and may have an
idea how to replace it.
That clip appears to be an rotation stopped for the outer race of the bearing. I am amused that they thick so highly of the part.
The only critical part of it is the spring temper. I am guessing that the Onan bearing has two cuts ground into the outer race and that spring is
supposed to hook into those and ride into the end bell when during assembly. It sure was a cheap answer 50 years ago.
As it is a double sealed bearing and open at the back there has to be some way to put something in there that will serve. I will have to look at what
I have when I am out in my barn next. I don't think I have one loose, but I may have an idea if I look at the beast.
