>If you look at the picture on my page and you have a hour meter, you will
>see the 12 volt wire goes to the hour meter. That is the one to use. If
>you this does not work , you should be able to use the position of the wire
>on the switch to indicate the correct wire.
My hour meter is located in the electrical panel near the "buzz" box. It seems
like if I find the
terminal on the start/stop switch which causes the switch light to come on, this
will also cause the
fuel pump to run. Am I correct?
Thanks
eric.henning
73 sequoia
like if I find the
will also cause the
Thanks
eric.henning
73 sequoia
