Onan oil leaks
james bolick
164
1) My Onan 4kw gen. has oil all over it. As far as I can tell it is due
mostly to the oil dip stick not sealing good.
Eric, I had the same problem and finally discovered that I was not pushing
the dip stick hard enough into the tube to get a good seal. On my Onan you
really have to push hard on the dip stick and it will and it will pop into
place.
Jim Bolick
"73 Painted Desert
there is a good chance the breather hose is collapsed take a look a the
web site.
gene
>place.
>Jim Bolick
>"73 Painted Desert >>
>I recall reading somewhere that you can replace the older style push in
>dipstick with the newer type that is on my 1977 GMC Onan. It is a fill cap
>that has a dipstick mounted to the bottom side. You put it on and turn it
>just as you would do to the oil fill cap on the engine oil fill.
>Emery Stora
>77 Kingsley
>Santa Fe, NM
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
While a major cause of oil leaks in an Onan 6 is the oil pressure switch,
oil will splash out of the crankcase when the engine is running and the
combo dipstick/ cap is removed.The reason for this in non-technical terms
is very simple: the crankcase is shallow and the combo dipstick/ cap
opening is large..
David Lee Greenberg
GMC Motorhome Registry
Dedicated to the preservation of the Classic GMC
http://www.gmcss.com/registry.htm
