Onan oil filters
neely butler
204
Some while back someone listed several filters that would work for the Onan
6000. I bought the Fram but it was too long. If anyone has the list would
you please show it again??
Thanks
Neely B. TN
'78 Elengaza II
I'm not sure if my solution will work on all models, but on my 75 PB I have
been using the same filter that works on my 1986 VW Jetta. The fram # is
2870A. Again, I'm not sure if all Onan's have the same filter setup, so
don't shoot me if I'm wrong.
Tony
To: GMC chat
Sent: Friday, October 29, 1999 2:19 PM
Subject: GMC: Onan oil filters
Onan
would
> Thanks
> Neely B. TN
> '78 Elengaza II
I recorded this earlier:
WIX 51342 - NAPA 1342 PH28A PH2870 Mopar 323 Purolator FCO-252
Chuck
77 K
North ID
>Tony
>From: Neely Butler
>To: GMC chat
>Onan
>would
>> Thanks
>> Neely B. TN
>> '78 Elengaza II
A Motorcraft FL-271, NAPA 1792, and Purolator FCO-252, should be the
equivalent to the Fram PH 2870 that I use in the generator. Onan number is
122-0445.
Paul Bartz
Sent: Friday, October 29, 1999 4:34 PM
Tony
To: GMC chat
also remember that the substitute filters do not have the bypass valve that
protects the Onan in cold weather. I bought my Onan filter in Albq. for $7
so I am not sure it is worth the savings.
gene
>Chuck
>77 K
>North ID
>From: Antnip
>>Tony
>>From: Neely Butler
>>To: GMC chat
>>Onan
>>would
>>> Thanks
>>> Neely B. TN
>>> '78 Elengaza II
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
Neely,
The following filters should fit the Onan:
Lee LP-2131
Mopar L-323
Motorcraft FL-271
Purolator FCO-252
Deutsch(AutoZone) D484 (This is the one that I use)
Fram PH-2870
Baldwin B-243
Hastings 134
NAPA 1324
Wix 51762
AC PF-56
Onan 122-0323 & 122-0445
J.R. Wright
> Thanks
> Neely B. TN
> '78 Elengaza II
Hi All
>From my research it appears all automotive oil filters have bypass valves.
Check here for more info
http://minimopar.simplenet.com/oilfilterstudy.html
http://www.mr2.com/TEXT/oil_filter_test.html
Dave
To:
Sent: Friday, October 29, 1999 4:22 PM
Subject: Re: GMC: Onan oil filters
> In a message dated 10/29/99 4:48:18 PM Central Daylight Time,
powerjon
> Lee LP-2131
> Mopar L-323
> Motorcraft FL-271
> Purolator FCO-252
> Fram PH-2870
> Baldwin B-243
> Hastings 134
> NAPA 1324
> Wix 51762
> AC PF-56
> But which ones have the check valve????
All automotive types have bypass valves. Just because it's an Onan
doesn't make it special just more expensive.
J.R. Wright
> In a message dated 10/29/99 4:48:18 PM Central Daylight Time, powerjon
> Lee LP-2131
> Mopar L-323
> Motorcraft FL-271
> Purolator FCO-252
> Fram PH-2870
> Baldwin B-243
> Hastings 134
> NAPA 1324
> Wix 51762
> AC PF-56
Great news, I will update my page
gene
>J.R. Wright
powerjon
>> Lee LP-2131
>> Mopar L-323
>> Motorcraft FL-271
>> Purolator FCO-252
>> Fram PH-2870
>> Baldwin B-243
>> Hastings 134
>> NAPA 1324
>> Wix 51762
>> AC PF-56
mr.erf
> Purolator FCO-252
Please tell me if I am wrong, but this is not the correct number for the
Purolator. This was the number listed in the cross reference manual and
I believe its a mis-print. It has shown up here on the list several
times and people I asked (at a Philly Pep-Boys) tell me there is no such
model #. I used a purolator and it was a all numeric #, if my memory
is correct, it was 520252. The box lists at least the FRAM as a cross
reference. If the FCO-252 is correct, I would like to know so I can
pull the other one off my Onan. Thanks, walter bright, 76 GB.
Walter
Sorry I can't clear the air for you on this filter number. It's not one
that I use nor have tried to obtain. I just recorded the number from an
earlier Onan filter discussion here.
Chuck
>> Purolator FCO-252
