onan no make electric
gene
2,215
Hi
I was wondering if you made the measurements shown here?
http://www.california.com/~eagle/generator.html
gene
>i just had a new bearing,brushes and board installed on the generator. it
> started onece on its own after that i have to jump 9 and 11 to get it
> started and it ran fine making electric. i ran the gen for about 2 hours
> total at different times. now it wont make electric. the motor still
> starts and runs but no elec. i changed the bridge rectifier no0 help. i
> took it to the local onan dealer and he estimates it will cost 500 1000
> to fix. i guess he didnt want to do it. what should i check for now? i
> have it out of the coach.
>thanx
>chris 75gb
>____________________________________________________________________
>Get your own FREE, personal Netscape WebMail account today at
http://webmail.netscape.com.
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
>thanx
>chris 75gb
Chris - Where are you checking to see if you have voltage? Take off
the cover of the reset button that is on the top center of the Onan.
Check to see if you have 120 volts (more or less) on each side of the
switch. If only on one side, press the reset and see if you now have
it on the other side. If not, you have a defective reset switch. If
no voltage on either side then it is in the rectifier, brushes,
wiring or other internal components in the Onan generator.
Emery Stora
77 Kingsley
Santa Fe, NM
