Well here it goes on short notice.
We are going to have an Onan Mini Rally at John Bush's home in Sonol ,
Ca. We are going to install the electronic ignition kits the Mr.C was
able to purchase for us. Since this is short notice, if you cannot make it
, we might do it again some time in the future. We will probably also do
all or some of the following Simmons Onan upgrades while we are at
it. Remember to bring your own parts..... We will not have extra parts there.
If you let me know in time, I will bring the parts for the Primer
Button. The map to John's place is here:
http://albums.photopoint.com/j/AlbumIndex?u=128904&a=2066855
He has offered parking for sleep-overs if you are interested. We hope to
do the following up grades if you have the parts. Your Onan should be
already running and working since we don't want to make modifications that
we cannot test..
Electronic Ignition install
Set timing
Set voltage / cycles
Remove Onan battery charger wires
Clean fuel filter
Replace Air filter
Change Oil (Bring own oil, filter,and containers)
Check Starter Brackets
Check rubber mountings
Change spark plugs
Install Primer button
Remove / check fuel shut off solenoid
I don't think we can get to the fuel line and connector replacement. But
we will discuss these upgrades.
Hope to see you there Sat . Please send me an email if you plan to
attend. If you need detailed instructions on how to get to John's house,
let me know.
Gene
Genef -- 77PB/ore/ca
GMC MOTORHOME INFORMATION
mr.erf
