Duane,
I have a low oil switch that I was going to use on the GMC
with my new dash panel. It is "normally closed pressure
switch type" but I think only closes at about 7 PSI if I
recall correctly. If it fits the threads would that be adequate?
Richard Waters '76 PB, with Onan apart, Troy, MI
> The Onan Oil Pressure switch as well as the K-1 Starter Relay are common
> with the Automotive Components & should be available at most Auto Parts.
> Take the old one with you ..normally closed pressure switch type
> (closed w/o oil pressure).
> Thanks
> Duane
> ________________________________________________________________
> Prodigy Members:
> Try Juno Web free for a full month and experience the difference!
> Download your free software today: http://dl.www.juno.com/dynoget/tagp.
> -------- REPLY, End of original message --------
> Gene 76Palm Beach /Or/CA
> GMC Technical Information
> http://www.california.com/~eagle/
Duane,
> Thanks
> Duane
> Prodigy Members:
