Larry
You should be able to test the Hobbs meter by removing it from the circuit
and applying the appropriate voltage to the terminals. I don't know if
these are 12V DC or 120V AC, but application of the proper voltage would
indicate if the meter is operational or not.
Chuck
77K
North Idaho
> From: LNelson208
> To: gmcmotorhome
> Subject: GMC: Onan, lord of light, part 2
> Date: Wednesday, November 18, 1998 2:06 PM
> Update: She purrs like a kitten now, BUT, I was forced to "help" her at
each
> start, warm or cold. My "help" involved "encouraging the governor arm to
close
> off the throttle just a bit after the start. Doing that, the engine
smoothed
> out and ran great with no help from me. If I didn't, it would run rough,
> obviously rich, and never smooth out. Looking at the manual
troubleshooting
> chart, it indicated one scenario that the nozzle boss gasket leaked, and
that
> the engine would run with the power needle seated. My unit ran better
with the
> needle seated than open 1 5/8 turns as directed. I had torn down the carb
> several times in my search for the "purr". I tightened the bowl retainer
nut
> as far as I dared, and now she starts fine and runs fine. (The bowl did
not
> leak fuel!). Just where is the nozzle boss gasket (got all the books!)???
I
> still feel she runs a bit rich. Also, my Hobbs meter is inoperative, and
> frankly, I don't know if it ever works during my short ownership. Is
there a
> test a moron can perform to check the meter? BTW, I used my "Good
Governor"
> to set the unit smack dab on 60 hz. It runs at 127 volts at 60 Hz. Larry
> Nelson, PB 75, sweating it out in NOV. in southern MO.
Chuck
77K
North Idaho
> From: LNelson208
> To: gmcmotorhome
each
close
smoothed
troubleshooting
that
with the
nut
not
I
there a
Governor"
