Generator stopped putting out AC power this weekend. Changed the bridge rectifier which got it going for a few minutes, but the real issue is the
brushes.
Some has installed one set of brushes with the brush contact wire going over the brush spring, holding it off the slip rings once it wore a bit. This
has arced one of the slip rings causing the opposite brush which was installed correctly, to wear down to nothing now.
I can get replacement 214-0096 brushes from carbonbrush.com, but I was wondering if anyone has come up with a better replacement. The 1/4" quick
connects are broken and the brush contacts have been soldered on.
Thanks
Bruce Hislop
ON Canada
brushes.
Thanks
Bruce Hislop
ON Canada
