The generator does not put out 220. The leads to your breaker panel are
split from the output of the genset. That is the two cables that come off
the genset divide and feed 2 sides of your panel. This gives you 110 on
each side but not 220. I was a little confused at first but it was
explained to me that 2 x 110 does not equal 220. Your genset gives out a
ton of amperage (50 I think) .This many amps gives you enough to run two
13500btu air conditioners. The only way to get 220 out of your genset is
to double the rpms but this will make very very short your genny life.
> 1) Does the generator put out 220?
> 2) If the rectifier is removed and am electrical voltage tester touched
> to + and - at the harness will there be a reading if generator is
> producing current?
> Frank SW Indiana
> ______________________________________________________
> Get Your Private, Free Email at http://www.hotmail.com
> producing current?
> Frank SW Indiana
